502 Mag cooling system problem >
Old 07-04-2013 | 08:38 AM
Default 502 Mag cooling system problem
My water line from thermostat housing to water pump is blowing off above 3500 RPM. The engine is running cool. Do I have a head gasket issue or thermostat housing obstruction to bypass circuit? Also, can I remove the thermostat without removing anything else?
robmay is offline
Old 07-04-2013 | 11:35 AM
Took out a restricter and replaced thermostat (160). Now the only issue is that the engine never exceeds 140 (as measured on a bypass line). Should I try to resolve this?
robmay is offline
Old 07-07-2013 | 07:26 PM
mspdoc's Avatar
same thing happened to me in june. toasted my engine. have you found anything out on why?
mspdoc is offline
Old 07-08-2013 | 04:01 PM
You can remove the T stat, just be careful not to break the white plastic retainer.
Just remember, EFI engines like heat. If it is in tact an EFI, you will soot the transom, get terrible fuel economy, and most likely wash the oil off the cylinder walls.
justinp20012500 is offline
