Formula 303 drive question? >
Old 07-05-2013 | 11:14 PM
Default Formula 303 drive question?
I have a Formula 303 SR-1(Fastec) with bravo one drives.
I noticed today that the starboard drive roster tail is 2 feet shorter than the port side. The performance did not seem to be hindered but I can only go 45 on my lake so I could not get it up to cruise or top speed. I put it up on the lift and both drives are in perfect alignment. Anyone have this happen to them? Any way to check the drives to make sure they are ok? Any suggestions are welcome.
Chuck B.
Snoworks is offline
Old 07-06-2013 | 07:04 AM
Are both drives trimming to the same height?
Unlimited jd is offline
Old 07-06-2013 | 11:46 AM
They look to be trimming to the same height.
Snoworks is offline
Old 07-06-2013 | 12:24 PM
Could be your props, you could try a different set or switch and run the boat in reverse to see if it stays with the drive or prop.
s022mag is offline
