Go Back  Offshoreonly.com > Owners Forum > Powerquest
5 Blades, anyone on a Vyper or Avenger Run Them? >
Old 07-10-2013 | 09:56 AM
Default 5 Blades, anyone on a Vyper or Avenger Run Them?
What year?
What props did you remove?
How did they compare?
What 5 blades did you put on?
Any other info you can share?
Pwraddr is offline
Old 07-10-2013 | 12:04 PM
Keith,
I have a set of Maximus 5 blade 32" pitch that were on the boat when I bought it. Hole-shot was great but I wasn't hitting peak rpm. Changed to Bravo 4 blade 30" that have been worked over a little. Rpm and speed was great with these props. Now that I have the Whipples going on I'll have to re-evaluate...
Need4SpeedGTCS is offline
Old 07-11-2013 | 05:37 PM
I have run 29 Hydromotives P5X's and the hole shot and midrange were awesome. I had the diffusers cut off trying different things.....well that didn't work and now they will be welded back on.
I am now running 30 Bravo 1's and they hole shot pretty damn good as well.
Doesn't seem to matter what props are on as the 525's run hard!!
verbi69 is offline
