525 efi intakes >
525 efi intakes
525 efi intakes
Old 07-13-2013 | 10:36 PM
twisted mentality's Avatar
Default 525 efi intakes
Has anyone had any luck with 525efi with prochargers on them? I'm running a modified 509 with a m1 and was wondering if this intake set up would work well with my motor. I'm now running a 502 mag mpi set up that has been machined down with a larger throttle body and was wondering if the 525 efi setup would be a better replacement with larger injectors and throttle body?
twisted mentality is offline
Old 07-14-2013 | 07:37 AM
I would run a aftermarket EFI with that setup...to many limitations with the factory intake/ECM's...sure some will disagree....
ezstriper is offline
