Mercruiser Trim Pump Assembly
New never installed pump out of box, shows slight wear from sitting on my shelf. This pump has the Quick Connect trim line fittings, they can be removed and connectors can be used to adapt this pump to fit older application. This pump assembly will fit most Alpha Generation II Applications and most Bravo I,II, and III applications and comes with a bracket to mount either on the floor or the transom. I put fluid in it and bench tested it yesterday, the fluid will be removed before shipping. Its this assembly.
http://www.boats.net/parts/detail/me...865380A25.html
Pics
$325 shipped to the lower 48
Pics
