496 Temporary Overheat? >
Old 07-21-2013 | 01:51 PM
Default 496 Temporary Overheat?
Hey guys...new to this boat and the 496. This was my first time out with this Ultra and it had been sitting about a week and a half since it was in the water last. When I launched it, I had to idle in neutral in the marina for a few minutes while I waited to pick up my buddy. About 5 min into idleing, a overheat alarm went off. Gauge only showed about 150 but still alarming. I lifted the hatch and felt the manifold and about melted my hand off. Turned motor off for a minute then started it back up. Alarm was still going off but gauge still only showed 150-160. I idled in to pick up my friend and spun around to idle out of the marina.....alarm still going off. After about 1 minute of idling in gear and then getting onto plane, the alarm shut off.
so obviously, when sitting still, the motor wasn't pulling in enough water to keep cool. so my question is, is that "normal" for that to happen the first time back in the water since all the water was drained out OR do I have some sort of pump/impeller issue? The dealership told me they put a brand new pump and impeller in it right before I took it home.
thanks guys.
Lanceg is offline
Old 07-21-2013 | 02:40 PM
thanks guys.
haw many hours on engine?? hate to tell you this but the 496 engine seapumps are known to go bad andare expensive to fix..i recomend getting the hardin or cp performance one this way is wont go bad so fast..the after market is a better design and cheaper then the 600+ dollars that merc wants for their junk..http://www.cpperformance.com/p-15774...d-502-mag.aspx
FIXX is offline
Old 07-21-2013 | 02:55 PM
Since you mentioned the impeller was replaced I would lean toward what could be wrong due to that. Either they really didn't change the impeller and should have or they did and used the air system to drain the water out and didn't release the air from the system afterward. Just a thought. Was there extra water in the bilge? Or like FIXX said, pump itself a common problem.
vindicator101 is offline
Old 07-21-2013 | 04:04 PM
motor has 125 hrs on it. it got a new seawater pump along with the impellar when I bought it (at least that's what they told me). no extra water in the bilge either.
Lanceg is offline
Old 07-21-2013 | 04:50 PM
if that is the case then replace the water pressure sensor,,those are common problems as to they plug up with chit and wont register at low water psi..when the water temp gets to 190~220* then start to worrie..
FIXX is offline
Old 07-21-2013 | 05:10 PM
thanks man i'll check it out. where is that sensor on the motor?
Lanceg is offline
Old 07-21-2013 | 06:08 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
How old is the motor? Has the antifreeze been replaced? The AF should be bright pink/peach. If it is grey/metallic it's old and needs replaced. It silts up and and does not flow as well. It's only good for 6-7 seasons max.
Also, do you have a fresh water flush connection on the boat? Make sure the cap is closed AIR-TIGHT if you do.
Sometimes, those systems have spring loaded check ball systems that can get gummed up with sand, weeds, and debris from the water; which also cause overheats.
You could have an obstruction that is not allowing enough flow at low speeds, but adequate at higher speeds.
If you do not have a water pressure gauge, it's advisable to have one. If you want to see an overheat via alarm or gauge, it's too late and your impeller has started moving through the cooling system. A water pressure gauge will tell you if you have picked up a bag or something on the drive and restricted waterflow immediately.
I've also posted many times before, that you really owe it to yourself to buy a www.rinda.com scanner for that motor. It will save you hours upon hours of troubleshooting time. It's the best $500 I've ever spent on any boat.
Sydwayz is offline
Old 07-21-2013 | 09:17 PM
Coolant looks brand new. no obstructions in any of the water pickups either. Im going to back the boat in the water in the am and let it idle on the trailer to see if it happens again.
Im not sure about the freshwater flush cconnection...is that supposed to be on the drive?
Lanceg is offline
Old 07-22-2013 | 06:44 AM
Im either missing the sarcasm here or you didn't read the part where i said it got a new pump and impeller???
Lanceg is offline
Old 07-22-2013 | 07:59 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Fresh water flush connection would be a garden hose connector somewhere in the engine compartment or perhaps on the transom. Some manufacturers install them, and some do not. Do you have a sea strainer? (small little coffee can looking thing in the bottom of the boat with a clear window and a basket inside to strain out seaweed and debris before it goes in the engine)
Sydwayz is offline
