Baja 275 with a 496 HO
Old 07-21-2013 | 05:43 PM
Default Baja 275 with a 496 HO
My 2003 Baja 275 with a 496 HO and a 25 pitch prop used to go 67 MPH on GPS at 4800 RPM but now it goes 63 MPH at 4500 RPM, what happened?
peaceman34 is offline
Old 07-21-2013 | 06:18 PM
It slowed down.
When was "used to"? What has changed since then? Weather? When did you last change fuel filters? Have you ever cleaned screen in cool fuel assy? A lot of experienced minds on OSO, you need to give more info.
sbracing is offline
Old 07-21-2013 | 07:04 PM
Sorry but I didn't do anything. It ran 67 mph 4 weeks ago on the Ohio river hear in Cincinnati and now it doesn't. I have not cleaned the screen in the cool fuel assy. I don't even know where that is. Sorry I am new to this boat and engine, we got it 8 weeks ago. Any help would be appreciated.
Old 07-21-2013 | 09:28 PM
Gas without ethanol compared to gas with ethanol? Mine runs a lot better without alcohol.
Merc-Mate is offline
Old 07-22-2013 | 12:47 AM
Air temp, humidity, river current, and amount of fuel and people could easily account for that loss in mph.
Griff is offline
Old 07-22-2013 | 07:31 AM
fountain27ho496's Avatar
If it sets in the water a dirty bottom would do it.
fountain27ho496 is offline
Old 07-22-2013 | 06:49 PM
Thanks guys I think my fuel filter is suspect. I did put some Lucas injected cleaner in there a probably clogged the screen. The bottom is clean, I know the boat goes faster on the GPS downstream with a fast current. I know weight effects max speed.
I bought a new filter and screen today I'll let you know.
Thanks again and maybe I'll see you at the lake Cumberland raft up August 10th.
Old 07-22-2013 | 09:20 PM
Guardian mode
Does it beep twice at key turn?
Back4More is offline
Old 07-23-2013 | 09:32 PM
I will check.
Old 07-24-2013 | 10:46 AM
Up river vs down river??
Baja_man is offline
