what is a good qualit and resonably timing set and timing cover for a stock 1990 7.4? >
Old 07-23-2013 | 08:52 PM
Default what is a good qualit and resonably timing set and timing cover for a stock 1990 7.4?
I just picked up a sundancer with a single 454. The timing cover was rusted through and while I am there I should install a roller timing set . The engine is stock and I am looking for an inexpensive quality timing set and cover
schurgervt is offline
Old 07-25-2013 | 07:56 PM
inexpensive and quality are 2 words that dont belong togeather,if you want quality buy a cloyes timing set and an edelbrock aluminum timing cover,if you want cheep i dont know that answer because i dont go that route.
mike tkach is offline
Old 07-26-2013 | 01:47 AM
I agree with mike. I have the edelbrock aluminum covers and like them.
Timing cover rusted through? What's the rest of the engine looking like ?
MILD THUNDER is offline
Old 07-26-2013 | 09:09 AM
The circ. pump is probably leaking. That's what caused the timing cover to rust through. Be sure to check/replace the pump.
Eddie
Young Performance is offline
