Anyone have a male 3 prong plug that plugs into the mercruiser trim pump? >
Old 07-25-2013 | 08:30 AM
Default Anyone have a male 3 prong plug that plugs into the mercruiser trim pump?
I am looking for the 3 prong male plug that comes with your boat harness or controls harness that plugs into the mercruiser power trim pump. The last guy cut the power lead and broke the tab off on the plug. I will post a pic of the male and female plug so you can understand what I'm talking about. I only need the male plug that is on the wiring harness. It should have 3 or 4 wires going to it. blue/green/red maybe. If I could get one out with about 12 inches of wire that would be great.
[ATTACH=CONFIG]505021[/ATTACH][ATTACH=CONFIG]505022[/ATTACH]
Attached Thumbnails Anyone have a male 3 prong plug that plugs into the mercruiser trim pump?-trimpumpplug_female.jpg   Anyone have a male 3 prong plug that plugs into the mercruiser trim pump?-trimpumpplug_male.jpg
FBRONCO is offline
Old 07-25-2013 | 10:59 AM
Get some flat spade crimp ends from your local auto parts store and make your own.
f_inscreenname is offline
Old 07-25-2013 | 11:26 AM
I know I could make my own connections... I just wanted to have the clean factory look of the 3 spade plug.
FBRONCO is offline
Old 07-25-2013 | 02:58 PM
c_deezy's Avatar
I would just put ring lugs on and put them directly on the solenoids.
c_deezy is offline
