502 efi's water pressure gauge's >
Old 07-25-2013 | 11:14 AM
Default 502 efi's water pressure gauge's
going to put a set of water pressure gauges on a pair of 502 mpi's..... where is the best place to put the fitting??? should a drill and tap the t-stat housing?? or is there a plug somewhere else that i can just put the fitting into..... thanks for any help!!!!
performance334 is offline
Old 07-25-2013 | 12:38 PM
My old 502 had a fitting on the starboard side of the block, below the middle spark plugs. (stock/factory configuration).
It's probably a water drain plug on yours. Use that.
ALL_IN! is offline
Old 07-26-2013 | 11:10 AM
ill check that out!!! thanks !!!
Old 07-26-2013 | 04:05 PM
The problem with the block drains is the lines to the guage's will get plugged up with sand.
Revd Up is offline
Old 08-01-2013 | 10:59 PM
Mine is in the intake manifold near the thermostat. I don't have the stock set up anymore. Try and find a spot near the thermostat.
Revd Up is offline
Old 08-02-2013 | 01:31 AM
ritatud is offline
