Prop wont go any faster. >
Old 07-26-2013 | 09:30 PM
Default Prop wont go any faster.
I have an 18ft Formula. I built a 355. No matter what prop I put on it, it wont go any faster than 54mph. I tried it back to back. 21 aluminum, 23 aluminum, 21 Mirage plus, and a 23 Mirage. Both of the stainless props are in perfect condition. The motor will rev faster but no speed is ever gained past 54 on gps. It feels like i am doing a burnout. Could a crooked and rough skeg cause this?
79formula is offline
Old 07-26-2013 | 09:47 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
What is the condition of the bottom of the boat? Any bottom paint, growth, or other? It sounds like you have something robbing hydrodynamics; which could be the skeg. Does it track straight? Have you run a prop slip calculator with the different props and RPMs? Have you tried a 4 blade? Are you sure the engine coupler is in good shape?
Sydwayz is offline
Old 07-26-2013 | 09:51 PM
racinfever's Avatar
Your drive is to deep
racinfever is offline
Old 07-26-2013 | 09:53 PM
So an alpha SS would probably work wonders for me then? Are there any band aid fixes for a drive thats too deep? And why would Formula mount a drive so far down?
Old 07-26-2013 | 09:55 PM
The bottom of the boat is perfect, coupler has been verified good. I consistantly get high slip numbers.
Old 07-26-2013 | 10:14 PM
what ignition does the boat have,does it have a rev limiter?
mike tkach is offline
Old 07-26-2013 | 10:19 PM
It has an old school Mallory Mercruiser points setup with a points eliminator kit. I have also checked my advance curve and it is within spec. I can rev to 6k but get no gain in speed.
Old 07-26-2013 | 10:26 PM
ok,that rules out what i was thinking,maybe something is causing the prop to loose it,s dynamic hookup with the water as others have said.
Old 07-26-2013 | 10:41 PM
Ill be bummed if I rebuilt the transom, rebuilt the drive, built a 400hp motor, all to gain 0 mph. I really wanted to go for 60s, if the drive is too low it will be where my quest for speed ends til I can buy a 242.
Old 07-26-2013 | 10:43 PM
GPM
How fast did it run before you built the motor ? what parts did you use, heads, cam, intake, carb, compression, Exhaust ? you may not be making the power where you need it,
GPM is offline
