Suggestions for GoPro on Transom videos??? >
Old 07-27-2013 | 02:18 PM
Strip Poker 388's Avatar
Rob
Default Suggestions for GoPro on Transom videos???
[ATTACH=CONFIG]505141[/ATTACH][ATTACH=CONFIG]505140[/ATTACH][ATTACH=CONFIG]505139[/ATTACH]
I have the gopro2,Im trying to figure the best settings, and bet way/place to mount it,I need some advice [ATTACH=CONFIG]505142[/ATTACH]
on the transom I getting alot of spray from the exhaust,water on the lens.
On the engine hatch a little vibration
In the ending compartment more vibration
On the side of the boat its ok
Where do I down load it to put it on the net? I have a pro photobucket acc and it downloads,but the play back quality is reduced and you see the dot matrix squares too.there around 200meg file
Youtube would be worse,
what about the frame rate?
Thanks for any help
Rob
http://s19.photobucket.com/user/Stri...b6237.mp4.html
Attached Thumbnails Suggestions for GoPro on Transom videos???-vlcsnap-2013-07-24-12h41m17s2.jpg   Suggestions for GoPro on Transom videos???-vlcsnap-2013-07-27-13h44m26s141.jpg   Suggestions for GoPro on Transom videos???-vlcsnap-2013-07-27-13h45m30s15.jpg
Strip Poker 388 is offline
Old 07-28-2013 | 02:10 AM
www.rammount.com has some nice options. You could use a universal band clamp roll bar style mount to the grab handle on the swim step.
offshorexcursion is offline
Old 07-28-2013 | 08:35 AM
I have the contour roam,I set mine on 720p @60fps.I then convert the file to avi and upload to you tube directly.As for mounts,ram mount w/ suction cup works great.I put it on the back of the boat w/ an extra high strength twine to tether it.
I find that when mounted on the bow,the waves just don't look as big when going at them.
sutphen 30 is offline
Old 07-28-2013 | 08:48 AM
Rob
so does the 60fps make a clearer video?
yea Ive got some paracord as a tether
got to figure out what the cleanest/clearest area on the transom so the exhaust water doesent covering up the view,
wonder if rainx would help
