HP500 fresh rebuild, 540 HP, 1 yr US WARRANTY >
Old 07-27-2013 | 07:42 PM
Default HP500 fresh rebuild, 540 HP, 1 yr US WARRANTY
Very nice HP500 rebuilt with awesome 540 HP and 535 torque! Dyno sheet and video! Freshwater only. Top notch engine builder.
New JE pistons, New Clevite bearings, New High Volume Melling oil pump, New Durabond coated cam bearings, New Moly rings, New Performance timing set, Manley SS Severe Duty valves, New valve guides and three angle performance valve job, Bore and hone block, New Fel-Pro gaskets, Clean/mag/grind and polished crankshaft. Includes intake, 750 marine carb, HP500 flame arrestor, dist, coil, wires, sea water pump, starter, water pump, water pump/crank pulleys, flywheel, thermostat housing and ss braided lines, fuel pump and fuel seperating filter mount and filter.
1 year U.S. NATIONWIDE WARRANTY (You can run two seasons under the 1 yr warranty 2013/2014!) Never in boat and the engine will be shipped directly from my engine builder Horn Engines in Marion, IA, 52302. (they are putting the 1 yr warranty on it). Video of motor on Dyno by the engine builder to be uploaded on Mon 7/29/13. Sounds great! Use freight quote.com for shipping estimate(I will pay the shipping to the lower 48 US states, dock to dock, only if full price is paid). $9,500/ offer. Call or email with any questions at 515-707-2063 or [email protected].
http://www.offshoreonly.com/classifi...mall/52789.jpg
http://www.offshoreonly.com/classifi...ll/52789_2.jpg
http://www.offshoreonly.com/classifi...ll/52789_1.jpg
Baja3725 is offline
Old 09-05-2013 | 07:00 AM
$8,900 offer
Baja3725 is offline
Old 10-27-2013 | 10:55 AM
Ttt
Baja3725 is offline
Old 01-27-2014 | 08:10 AM
Ttt
Baja3725 is offline
Old 01-29-2014 | 12:47 PM
You're photos are very small, might help your sale if you added larger ones. GLWS
Jordan is offline
Old 01-29-2014 | 02:03 PM
Thanks...will try to add bigger pics.
$8,900 / offer
Baja3725 is offline
Old 05-18-2014 | 06:27 AM
$8,500/offer
Baja3725 is offline
