HP 500 camshaft's Do they have a fuel pump lobe? >
Old 07-29-2013 | 10:12 AM
Default HP 500 camshaft's Do they have a fuel pump lobe?
My buddy wants to buy some used carb camshafts for his budget gen IV build. His sea pumps do not have fuel pumps so he would need a pump lobe.
Steve
smiklos@sunprint is offline
Old 07-29-2013 | 12:31 PM
No. I have two on the shelf from when i put the 525 cams in my hp's if you need one or both.
Rbesola is offline
Old 07-29-2013 | 02:36 PM
How much $$$$$
Steve
Old 07-29-2013 | 03:57 PM
Steve
Make sure he is running some type of exhaust with long risers or one that introduces the water near the transom. The 110* LSA and overlap on the HP500 carb cams tended to revert with the short risers or exhaust that do not have a sufficient degree of drop down to the transom.
Budman II is offline
Old 07-29-2013 | 06:40 PM
Thanks! He has full dry pipes so reversion should be the least of his worries. But with a budget build anything can go wrong.
Steve
Old 07-30-2013 | 08:03 PM
Is this a Mark IV engine with a fuel pump boss on the block? From the question it sounds like you want to put a Gen V or Gen VI cam with no fuel pump lobe. A good roller cam with fuel pump boss is not the expensive, its the lifters that get pricy.
1BIGJIM is offline
Old 07-31-2013 | 01:39 AM
pughdxk is offline
Old 07-31-2013 | 06:11 AM
Gen IV block
Old 07-31-2013 | 06:17 AM
Anybody ever use the lower dollar comp cam packages like http://www.compperformancegroupstore...=MARKIVCAMHRXM. I am trying to get him to pony up for RM builder stuff
Steve
