While my motor is out.... >
Old 08-01-2013 | 07:17 PM
Default While my motor is out....
Hi everyone, while my motor is out of my seebold I have some fiberglass work to do and then plan on freshening up the paint. My question is what else should I address in the motor well while everything is accessible? Gaskets, gimbal seals etc. Its a 454 bravo1 if that helps. Also anyone use the Magic implement paint from tractor supply in there bilge?
seebold 236 is offline
Old 08-01-2013 | 08:49 PM
Randy Nielsen's Avatar
Speaking from some experience, anything that you don't want to fix after the engine is back in. Now would be a good time to check all hoses, wiring, bilge pumps, cables, anything that could cause a problem or is questionable. As for the paint IDK never used it. Randy
Randy Nielsen is offline
Old 08-02-2013 | 05:46 AM
I would check out/replace your gimbal ring swivel shaft seal at minimum, those will tend to leak after they get old and a lot of times because the swivel shaft itself gets corroded and tears the seal. The Mercruiser Sea Core outdrives use a stainless steel swivel shaft. You can also get a stainless steel swivel shaft from JR Marine. You could consider adding engine compartment lights or a extra house battery if you don’t already.
johnny b good is offline
Old 08-02-2013 | 06:23 AM
Replace Trim Limit and Trim sending unit. Even if they are still working..
Chris
Blueabyss is offline
Old 08-02-2013 | 06:52 PM
Yea I am in the process of fixing all of the wiring now because someone hacked the harness up on two different places
