350 mag carb version roller or not ? >
Old 08-01-2013 | 08:33 PM
Default 350 mag carb version roller or not ?
Little help needed here. Looking at a 1994 mcm 350 mag carb engine serial # OF126045. Was wondering if this is a roller cam version or not without pulling apart. Been on mercruiserparts.com but can't figure out which one it is, did a little searching too ... Any help is appreciated!
TylerBurich is offline
Old 08-01-2013 | 11:38 PM
That's a late model motor and should be a hydraulic roller cam. Internals will likely be cast however (crank, rods and perhaps hypereutectic pistons).
Trash is offline
Old 08-02-2013 | 01:26 AM
its a non vortec so i doubt it will have a roller cam..all you need to do is pull a valve cover and look through one of the holes in the head..if you see the dogbones around the lifters then its a roller but i dont think they were those years..
FIXX is offline
Old 08-02-2013 | 06:10 AM
I agree...1994 was too early for roller or Vortec in a stock Mercruiser. Look for 1998 or later if that's what you're after.
sprink58 is offline
Old 08-02-2013 | 07:26 AM
Thanks guys, trying to order an engine for a customers boat should have been easy with the serial # I would have thought. We will get the non roller 95 and earlier version. Thanks again
Old 08-02-2013 | 08:36 AM
Knot 4 Me's Avatar
There was a thread in this section or the do it yourself section from a guy with a '94 Crownline and this topic came up and it turned out what most people thought would be a flat-tappet cam motor had a roller in it from Merc.
Edit - Post #25. '93 350 MAG with a factory roller cam.
http://www.offshoreonly.com/forums/g...ad-swap-3.html
Knot 4 Me is offline
Old 08-02-2013 | 10:02 AM
I can get to the engine tonight I think I might investigate a little further myself and verify what the internals are. Thanks for your help guys!
Old 08-02-2013 | 10:21 AM
Vortec heads aren't the deciding factor on whether or not a 350 has a roller cam. From what I have seen, most post 1990 350s have a roller cam.
Mr Maine is offline
Old 08-02-2013 | 11:39 AM
rmbuilder's Avatar
MarineKinetics
The production year 1987 was the beginning of the transition from flat tappet to roller cams. The changeover coincided with the introduction of the one piece rear seal block designed to eliminate the use of flat tappets. By 1988 the NOS with dealers was mostly installed and the production side was virtually exclusive to roller.
Bob
rmbuilder is offline
Old 08-02-2013 | 06:31 PM
It turned out to be a roller cam !
