REX Marine Rigid Tube Drive Shower >
Old 08-02-2013 | 10:40 PM
CBlakeNS's Avatar
Default REX Marine Rigid Tube Drive Shower
http://www.rexmar.com/page142.html - pictured in the bottom. Does anyone have the template for this?
CBlakeNS is offline
Old 08-03-2013 | 01:16 AM
Default fixx
you want to drill the hole on the port side and 1/2''x1/2'' in from the port side rear corner..
rex marine has been at this the longest and their website still sucks
FIXX is offline
Old 08-03-2013 | 05:48 PM
offshoredrillin's Avatar
Get the simrek no drill, woks greatand bolts right on.
offshoredrillin is offline
Old 08-03-2013 | 07:57 PM
CBlakeNS's Avatar
Is that for the pickup or the nut and bolt?
CBlakeNS is offline
Old 08-03-2013 | 11:44 PM
the pick up..once you get the bigger hole drilled you put the pick up in the hole and drill the smaller hole with the allen cap bolt and lock nut...the upper you remove one of the upper cap bolts and install the spacer and put the bolt through the shower head and spacer and torque it to 20 ft lbs..once installed make sure the prop clears the water pick up..if it dont your going to have to trim a little off but it should clear..also measure the one you got,,they are all welded in differant spots so the 1/2 '' x 1/2'' may have to be altered.
FIXX is offline
Old 08-04-2013 | 08:48 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Better double check that. Going by the pics, that would place the screw hole off the cav plate
US1 Fountain is offline
Old 08-04-2013 | 08:15 PM
read the end of post 5
FIXX is offline
Old 08-06-2013 | 11:39 AM
CBlakeNS's Avatar
Thanks I am going to take a look at it this weekend. Appreciate the replies.
CBlakeNS is offline
