Fuel injector line connector >
Old 08-06-2013 | 06:04 PM
Default Fuel injector line connector
Found some melting on an injector connector same one rinda found fault with f injector wire short. Anyone know a source for an individual connector to avoid buying entire harness; 2004 mercruiser 496 HO... Thanks
38fountained is offline
Old 08-06-2013 | 10:56 PM
Send a picture of the existing injector and or harness connector. Here's a brief list from Summit.
http://www.summitracing.com/search/d...nector-pigtail
Trash is offline
Old 08-09-2013 | 01:08 PM
you can buy pig tail repairs from about any national parts chain or your local GM dealer.
tunertech is offline
Old 08-09-2013 | 04:09 PM
Thanks I'll try a dealer, all other sources can't match it up......
Old 08-13-2013 | 04:29 PM
Pigtail came in installed perfect fit. Thanks Guys for info...... Ran the boat same problem. Running 3900 rpm. Problem engine laggs the other engine as far as throttle position/rpm. Then after a set time the engine rpm drops, constant horn sounds i reduce the throttle to idle horn goes out and I can push it up and run again. It will run at 3000 rpm so far all day long no issues. Oil pressures 50 psi, water pressures 26psi temps 165*... Possible fuel restriction??
Old 08-19-2013 | 09:34 PM
constant alarm should be oil pressure or overheat, might be faulty sensor.
keith2500hd is offline
Old 08-19-2013 | 10:17 PM
look here http://www.diyautotune.com/catalog/w...063a00792878e7
and here http://www.diyautotune.com/catalog/7...kit-p-380.html
FIXX is offline
Old 08-20-2013 | 07:51 AM
Thanks guys, got one on Partsgeek. Not a fix. Still get a steady alarm. Starboard temp sensor on exhaust is suspect. No alarm when sensor disconnected. Port side alarmed only at WOT after 5 minutes.. Will try a full flush.. Could a build up on sensor impact operation?
Old 08-20-2013 | 06:27 PM
the sensor gets plugged from debris and cant read water pressure.
FIXX is offline
Old 08-21-2013 | 04:36 PM
Do you think its just pressure sensor and not temp sensors....pressure sensor reads about 26psi when running...
