Getting another 100 hp from my 415 hp 502? >
Old 08-06-2013 | 09:56 PM
Default Getting another 100 hp from my 415 hp 502?
I have a 415 horsepower 502 and would like to get another 100 hp out of it. Any suggestions on what I should do? Head work, cam, exhaust? Is the merc exhaust ok with another 100 hp. Will I have reversion problems with the cam I will need? Thanks for any input.
riverrunner242 is offline
Old 08-07-2013 | 12:50 AM
Randy Nielsen's Avatar
I built a stock 509ci engine using all stock parts except the valve train. I went to Bob Madera @ Marine kinetics who set me up with an entire valve train setup but pushrods. Springs, retainers, locks, roller rocker arms, hydraulic roller lifters, cam and he recommended an air gap manifold & 850 quick fuel carb. With a DUI distributor this engine made over 500 lbft of torque from 2800-5300rpm & with a 1" spacer under the carb it made 512hp@5300 but would wind to5600 using dynoroom headers. I am pretty impressed for having to buy new stuff I spentjust under 3G for a turn key stump puller that will live for many hrs. Randy
Randy Nielsen is offline
Old 08-07-2013 | 12:55 AM
Stock Merc exhaust will revert water with any significant cam upgrade.
Griff is offline
Old 08-07-2013 | 01:01 AM
Stainless marine or EMI thunder should be ok & are mostly the least expensive. Possibly Lightning headers, not as expensive as CMI, etc. Randy
Old 08-07-2013 | 05:54 AM
look at he hp 500 / 502- 500 check the difference in cam exhaust heads carb . i believe the 525 use edelbrock performer heads with cmi exhaust .
tcal is offline
Old 08-07-2013 | 08:27 AM
Here you go
http://www.offshoreonly.com/forums/d...e-results.html
Chain Runner is offline
Old 08-07-2013 | 03:03 PM
mspdoc's Avatar
Mine has a pair of Graffig "cool chargers" . Similar to superchargers. It took mine up to 600hp. The company was sold to O2 Force (Powerdyne). Works good.
mspdoc is offline
Old 08-07-2013 | 04:59 PM
I’m also in the same boat as you with my 509, 088 heads, airgap & 496 manifolds. I was surprised to read here on the forums a guy running the 502ZZ cam & stock exhaust without reversion. Also read the original HP 500's (731 cams) had Gils and silent choice? I haven’t decided witch cam to use ( may just re use my 502 HO cam) but thought my 496 manifolds would be an improvement over the above exhausts with either cam.
Itsallgood995 is offline
Old 08-08-2013 | 01:30 PM
Thanks for all the input. I'll have to kick it around and see what i decide to do for a little winter project. I would really like to be going a bit faster next year.
Old 08-08-2013 | 02:08 PM
ProCharger...
You're welcome
TooLateVTEC is offline
