454 Vortec Spark plugs
Old 08-10-2013 | 05:08 PM
Default 454 Vortec Spark plugs
I have a 454 GM motor in my boat. block casting number 10237297 which comes up as a vortech motor. I assume that the heads would be Vortech heads, which then would take a longer spark plug. I have been running the Delco MR 43 TS, . But seem to be running really cool at idle. Just wanted to make sure i put in the right plugs, so not to damage the pistons. Serial number of the motor 12568777. Thanks. Dan
Baja 240 sport is offline
Old 08-10-2013 | 05:36 PM
jvthundercat's Avatar
They are a pretty good plug and should be fine for a BBC. I run Autolite APP25 I all my big blocks and they don't do that. If you want one up on that, just go to a XP25
jvthundercat is offline
Old 08-10-2013 | 06:18 PM
Thanks, I was thinking of putting in Delco MR 43LTS. But wanted to make sure not to hit the piston.
Old 08-11-2013 | 10:58 AM
if thats the base oval port engine it does take the longer plugs
ezstriper is offline
Old 08-11-2013 | 12:21 PM
Thanks, i do know it has rectangular port heads
