Hatch actuators on H2X
My hatch actuators seem to be out of sync, the left side lifts the hatch about 2 inches higher than the right, is there any way to adjust these? They seem to be the original ones.
Ed
Ed
The only way to adjust them is to move the mounts around. If you measure the actuators I bet you will find that they are the same length when fully open. The mounts are most likely not in the same position relative to the hatch so the change in geometry during operation props one side of the hatch up a little more than the other. If the uneven hatch bothers you then you can put stop collars on the actuators to limit their travel and get them to hold the hatch straight if you have the space and the spare stroke on the actuators.
Dan
Dan
