Fuel Leak
Old 08-12-2013 | 06:55 AM
Default Fuel Leak-6.2L MPI's
Was putting the boat away for the week last night and opened the hatch to check things over. I noticed a gasoline smell and after checking things out found gas residue around the cool fuel module on the starboard motor. I can't tell for sure, but it looks like it could be leaking around the fuel supply line. The hose clamp is tight as are all the other connections and screws holding the filter cover on. I have new filters and o-rings on order to replace this weekend, but wondering if anyone else has experienced a similar situation.
Dave
08 fastech 292 is offline
Old 08-12-2013 | 09:40 AM
I had a small leak from the supply (pump to seperator). It was a solid line so I replaced the brass fittings and the line and fixed it. Hopefully you have something as simple, but sometimes the simple things drive me more nuts than the big ones lol
sleev-les is offline
