Were to start >
Were to start
Were to start
Old 08-12-2013 | 12:25 PM
Default Were to start
02 cigarette gladiator w 900 blower motors I spin 4 blade 32 need help were to start
trannyjoe is offline
Old 08-12-2013 | 10:43 PM
fireboatpilot's Avatar
RIPSTA Racing Team
You spun 32's with what power prior to the 900's? Have you tried the 32's? What where the results? Need more info
fireboatpilot is offline
Old 08-13-2013 | 06:31 AM
just ran 4000 rpm hit 78 mph on GPS on the way up props slip at first start with the old 32s witch are from the old motors 500 efi just want to see if any body has did this before with the same boat trying to save time and $$$$$$$$$$$$$$$$
Old 08-15-2013 | 05:32 PM
bbladesprops's Avatar
Offshoreonly Advertiser
With a additional 800 HP you should run out of Bravo 1 pitch options since they only go to 36's.
This would create a gear change requirement.
Run the 32's harder and then we can see what is next.
We do have test propellers.
Brett
[email protected]
bbladesprops is offline
