What spark plugs to use?? >
Old 08-12-2013 | 03:23 PM
Default What spark plugs to use??
So what plugs does everyone use in there 502?? I switched my 96 502 from a mpi to a carb set up..so what plugs should I be using now?? Should I run the mpi plugs still or switch it over to the carbed plugs??
stlliberator is offline
Old 08-13-2013 | 04:05 PM
anyone??
Old 08-13-2013 | 07:50 PM
I use the Rapid Fire 4's from AC Delco. Gapped them to .038-.040 if I remember right. They make a new version and an old version. Get the older version if you can. I went to Oreillys and they had 8 of each so they brought in another 16 and most were actually the old version so worked out good. NGK makes good plugs too. You'll be in the 7 heat range. If your from STL your only about 15 mins from me. Where you normally boat?
Eliminated572 is offline
Old 08-14-2013 | 12:04 AM
Use the same plugs that you were. Stock plugs are AC MR43T or the NGK BR6FS.
Griff is offline
Old 08-14-2013 | 01:56 PM
We boat all over the place..mostly lately we just go to LOTO..but we do boat on the Mississippi..we have friends with house boats up there. We use to go to Carlyle lake all the time, but it got really boring after a while..where you boat?
Old 08-14-2013 | 05:43 PM
We have a place in harbor light bay on Carlyle. Also go to Kaskaskia a lot. We try to make trips to Bull shoals, table rock, or LOTO at least once a year
Old 08-14-2013 | 10:48 PM
NGK V Power racing plugs. Never had a problem with these plugs in a 650HP 502 with Dart Heads.
toyo321 is offline
Old 08-16-2013 | 12:32 AM
Use NGK BR6FS as mentioned.
Eddie
Young Performance is offline
Old 08-16-2013 | 12:38 AM
Same here. NGK racing plugs with good luck
MILD THUNDER is offline
Old 08-21-2013 | 09:12 PM
Toyo or Mild Thunder, do you have a P/N for the NGK V powers? and which is better the Projected tip or Non Projected tip?
CAPTAIN JACK is offline
