Carb Hat VS carb box on blow thru >
Old 08-13-2013 | 10:44 AM
Default Carb Hat VS carb box on blow thru
Anybody running a carb hat instead of the box ? anybody compaired the two ?
ezstriper is offline
Old 08-13-2013 | 10:55 AM
My buddy is now running a hat. He was running the box before. I am pretty sure he gained some power, and the hat is much easier access for tuning carb. His throttle shafts are oringed so fuel doesn't escape and leak. I think he got his hat from steve morris.
MILD THUNDER is offline
Old 08-13-2013 | 12:04 PM
who's carb did he use ? not all o-ringed I don't think...
Old 08-13-2013 | 12:07 PM
C&S . He switched from prosystems. He's Extremely happy with the C&S now.
Old 08-13-2013 | 12:09 PM
thanks..I ran a prosystems one for 2 years, but he only wanted me to run in the pain in a ass box...
Old 08-13-2013 | 12:19 PM
rmbuilder's Avatar
MarineKinetics
Rob,
You have a .pdf file in your email. It should provide data on this very question. It was to large a file to post on OSO, sorry.
Bob
rmbuilder is offline
Old 08-13-2013 | 01:30 PM
Bob, thanks...that was pretty interesting..not what you would think..Rob
Old 08-13-2013 | 05:19 PM
The hat is not uscg approved and neither is the oring or pressure fed sealed throttle shafts..if you have a fire on board and the carb is not in a box then the ins will deny the claim..
i have a friend that used a box first then used a hat,,really did not see any power increase..he did see more lower end power when i told him to get a more aggressive throttle linkage rod so the secondaries opened sooner..
FIXX is offline
Old 08-13-2013 | 07:41 PM
mgh
http://www.superiorairflow.com/
mgh is offline
Old 08-15-2013 | 01:13 PM
littledcsrodshop's Avatar
Is there any chance you could email me a copy of the pdf file ? I tried sending you a pm but your box is full..
Thanks for your time,
Scott C.
littledcsrodshop(at)comcast(dot)net
littledcsrodshop is offline
