502mpi uses oil, help
Old 08-14-2013 | 11:08 AM
Default 502mpi uses oil, help
Currently using m1 15/50. Someone on a thread don't use a SM rated oil as the M1 is. Motor runs good but burns oil.
In another thread they said use only 40. Does anyone have the hull truth?
Thank u so much.
236eagle is offline
Old 08-14-2013 | 11:22 AM
How much oil??? 502mpi's all use oil due to the stock low tension rings.
A quart every 8-15 hrs is pretty normal.
Griff is offline
Old 08-14-2013 | 11:44 AM
At least that. I saw on a thread don't use SM based oil. Whatever that means thanks for the reply.
236eagle is offline
Old 08-14-2013 | 05:52 PM
laster's Avatar
Sounds a lot like mine only you might be using less oil. I could go through a quart in 3-4 hrs. Changing oils didn't make much difference. Changing pistons and rings seems to have solved the problem completely.
laster is offline
Old 08-14-2013 | 06:10 PM
Mine went thru mobile 1 like crazy... Went back to straight 50w valvoline VR1 & made a very noticeable difference FWIW!
jmoore1225 is offline
