More from 350 Mag MPI
Old 08-15-2013 | 03:10 AM
Question More from 350 Mag MPI
I have a 350 Mag MPI in my 1998 22 Scarab. I would like to get some more power out of it. Anyone know of any good cam upgrades for this package? Thanks
Titan907 is offline
Old 08-15-2013 | 04:33 PM
How much more power are you looking for. That will determined how extensive the mods are. There are several good cams from Comp Cams, Crower etc that will work with a roller motor like yours. To optimize you should get the ECM tuned as well.
Trash is offline
Old 08-15-2013 | 05:14 PM
I guess I should start by asking how much horsepower the MPI manifold will support? I would like to get it up over 400 if possible. I am planning on upgrading to CMI E-Top headers as well. Thanks again.
Titan907 is offline
Old 08-15-2013 | 06:27 PM
Expensive Date's Avatar
it's my understanding that that stock manifold and fuel injection setup is going to keep you right about where you are headers will do nothing unless you change that or Pro chargeI personally would not procharge that engine with stock pistons
Expensive Date is offline
Old 08-15-2013 | 06:53 PM
I'm interested as well.
inlinepwr is offline
Old 08-17-2013 | 01:18 PM
A comp cam xm 276 would be as hot as one would want to go with wet exhasut a xm270 would be quite nice.You will notice it reqire's some modification's..and ground on a 112 lsa
http://www.carcraft.com/techarticles...pring_upgrade/
http://www.pacificp.com/forum/viewto...d21288c9eebedd
Page 2 is where the meat of the conversion come's to light
The below should be part of the thought process
http://www.perfprotech.com/blog/unca...d-and-checking
http://www.michel-christen.com/ExhaustElbows.pdf
Pliant is offline
Old 08-19-2013 | 03:08 AM
Thanks for the info Pliant. I was planning on upgrading to Imco exhaust, so that should take care of water ingestion issues. I like the Beehive springs too. :-D
Titan907 is offline
Old 08-24-2013 | 10:20 PM
I have twin 6.s MPIs in my boat. When I first got it I thought that there might be some easy horsepower left on the table. There isn't. The pro builders chimed in as well as many other experienced boaters. You have to do a complete package: heads, cam, intake, computer retune, and headers are over 2k. If I want to go faster I will buy a faster "stock" boat. You will spend a lot of money (don't forget a new prop) for 5-6 m.p.h. and probably not recoup your investment when you sell. JMO.
Wes Burmark is offline
Old 08-27-2013 | 04:40 PM
these marine mpi's don't have any real upgradability. they are good on fuel and dependable. but they are what they are for the most part. you want more power, go carb. alum heads-exh-intake. then keep the stock stuff to reinstall when you sell it...a large part of the speed increase is the 150 lbs you took outta the back of the boat with the lighter parts.
dereknkathy is offline
Old 08-27-2013 | 05:43 PM
I was worried the intake might not support much more horse power. I will still probably upgrade to Imco Powerflow exhaust to give it a little better sound and shave some weight. Thanks for all the info guys.
Titan907 is offline
