Cam specs? whats duration at.050?? >
Old 08-16-2013 | 05:24 AM
Full Force's Avatar
Default Cam specs? whats duration at.050??
My custom ground cam only has the advertised duration engraved, I do not have the cam card....
trying to see what duration it is....
I do know...
ground 114LCA
Says advertised duration 302/310
lift is .578
its erson.... cannot find what duration is @.050
how do I find that out??
Full Force is offline
Old 08-16-2013 | 05:44 AM
Depends where the advertised duration is measured at. .006, .004, etc
Do you have the valve IO/IC EO/EC numbers?
MILD THUNDER is offline
Old 08-16-2013 | 06:06 AM
Might be something like 242/248* @ .050 or in that range. Im guessing these were in those scarab engines?
Old 08-16-2013 | 06:12 AM
Full Force's Avatar
Yes that's the only thing I don't know... My buddy had a engine builder that I would have shot hence the reason I build my own stuff but this was a deal so I grabbed the boat....
I know he built them very conservative using small cams for the CI... I plan to change things in a couple years or if I hurt one and rebuild... These can make 675-700 hp easily...
Right now they are 598hp@5200 659tq@4200
Hp is 597-598 from 5100-5400 then drops off...
Tq peaks 4200 but still hold 607@5200 so 5200 is about what I wanna prop at also
Old 08-16-2013 | 06:13 AM
Full Force's Avatar
I don't only info is what's engraved on back of cam
Old 08-16-2013 | 06:31 AM
Put a degree wheel, dial indicator and pointer on it.
Unlimited jd is offline
Old 08-16-2013 | 06:33 AM
Full Force's Avatar
A little late now lol engines are in boat haha
I was just curious to see what they are...
Old 08-16-2013 | 08:00 AM
rmbuilder's Avatar
MarineKinetics
Full Force,
The cam is a derivative of the shelf cam:
E120207
RH-302-2
234º/242º @ .050"
.340"/.340" Lobe
Ground on a 114º Lobe sep
Attached is the cam card for theat cam on a 112º sep, measured with a 1.72 rocker ratio.
Bob
File Type: pdf
rmbuilder is offline
Old 08-16-2013 | 08:03 AM
Full Force's Avatar
Originally Posted by rmbuilder
Full Force,
E120207
RH-302-2
234º/242º @ .050"
.340"/.340" Lobe
Bob
So it's close to that? What's the 310 for on the back? Any idea? This cam seems small for 547ci aluminum head engines 320cc runners I think I have that info at home
Old 08-16-2013 | 08:22 AM
rmbuilder's Avatar
MarineKinetics
Yours is identical to the catalog cam sheet posted, with the exception of yours is ground on a 114º lobe separation angle, and the catalog cam has been ground on a 112º LSA. Duration, lift etc. is all the same.
the 302º/310º designates the seat, or measured duration. I posted the catalog cam to give you a look at the lobe architecture.
"Hp is 597-598 from 5100-5400 then drops off..."
That is typical of that duration for that displacement, power will plateau, dropping off due to pumping losses.
Bob
