Broke drive coupler! >
Old 08-19-2013 | 11:43 AM
Default Broke drive coupler!
I broke my drive coupler in the boat this weekend! Can or do any of you have tips or advice on what all parts should I go ahead change while I everything out like I know the coupler, gimbal bearing, seal, but what else or should I do?
Also I have not pulled the motor yet, but i did the drive and when I pulled the drive the gimbal bearing stayed on the shaft and came out with the drive anyone else have this happen? The boat has a 502 mpi with bravo one drive! Any help and parts list would be much thanks!
Mike S. is offline
Old 08-19-2013 | 11:57 AM
Never had that happen, hope your housing is ok but there could be an issue. Te bearing should be in there tight and take some work to get it out.
AllDodge is offline
Old 08-19-2013 | 02:16 PM
Yeah that's what I thought too, should take a little work to get it off but not here all of it sled right out wasn't expecting that to happen! I can't see to the eye any cracks in there but maybe I should remove the whole gimbal to have it looked at any thoughts?
Mike S. is offline
Old 08-19-2013 | 03:20 PM
GPM
You might want to check the alignment
GPM is offline
Old 08-19-2013 | 06:10 PM
I will! We was cruising along and hit a shallow sand bar (1' of water), to cause all this mess! Maybe I should have said that earlier! Everything else seams to be ok! I'm a little concerned about the transom though! Any thoughts?
Mike S. is offline
Old 08-19-2013 | 08:55 PM
does transom plate look like gimbal bearing locked=up and was spinning in it.
keith2500hd is offline
Old 08-20-2013 | 09:40 AM
No but I will dobble check it again when I get to the house! What would that mean of it was? New gimbal housing?
Mike S. is offline
