HELP!!! How to Remove Safe-T Steering >
Old 08-22-2013 | 11:01 AM
Default HELP!!! How to Remove Safe-T Steering
Hi Guys
I am stuck trying to remove this piece from the steering wheel.
I removed the bold holding this, but its really tight.
Is there a way of doing this I dont know?
Please let me know
Thank you!!!
andonixxx is offline
Old 08-22-2013 | 12:17 PM
Ebay Ed's Avatar
steering wheel / hub puller it bolts to the adapter that the steering wheel was bolted to and presses against the shaft put some pressure against it and then tap the tightening screw with a hammer should pop right off
www.bajaboatowners.com
Ebay Ed is offline
Old 08-22-2013 | 01:02 PM
tony davis's Avatar
Normally a hard whack on the end of the shaft loosens it. If not, then I normally sit on the dash facing aft, apply loads of pressure on the wheel with my thighs, whilst hitting the shaft with a hammer and centre punch. Try to not miss the shaft though, as it makes your eyes water!!!!!
tony davis is offline
Old 08-22-2013 | 05:36 PM
Ebay Ed's Avatar
Originally Posted by tony davis
try to not miss the shaft though, as it makes your eyes water!!!!!
roflmao
Ebay Ed is offline
