Protect Your Drives With The New Livorsi Drive Temperature Kit
New Drive Temperature Kit
Livorsi’s new drive temperature kit accurately measures the oil (gear lube) temperature of your drive. The majority of all drive failures begin with the drive generating excessive heat. This overheating can only be detected by measuring the gear oil temperature directly from the drive.
Drives are expensive, why not take proactive measures to protect them?
This kit keeps you alert of overheating that maybe caused by:
o Damage to propeller or bent shaft
o Water pump failure
o Condition of gear oil or loss of gear oil
o Water ingestion
o Outdrive seal failure
o Gear and bearing condition
Drive temperature is displayed on an easy to read 2 1/16” gauge. The use of water resistant, dust proof Deutsch connecters simplifies wiring and installs easily to most outdrives.
Help maintain the performance and longevity of your drives, and protect them with the help of the new Livorsi drive temperature kit.
Gauge Size:
2 1/16" cutout, 2 3/8" overall
Kit Includes:
gauge, 25 ft harness, thru hull fitting and temperature probe.
Part Number:
DCSDTK + dial color + rim color + rim style
List price: $274.00 (sold as a kit only)
Applications:
• Mercury Alpha and Bravo Drives
• Other drives – call for information
• Note: Verification of adequate clearance is required
