1999 7.4 vortec L-19 heads inconel exhaust valves? >
Old 08-24-2013 | 02:23 PM
Default 1999 7.4 vortec L-29 heads inconel exhaust valves?
Just picked up some excellent condition 1999 L-29 vortec heads up for $100. I have heard these are equipped with inconel exhaust valves as they were used on heavy duty trucks? Is this true? Plan on using stock valves and merely cleaning castings up as most data shows larger valves and porting just hurts these offerings. Thanks
Borgie is offline
Old 08-25-2013 | 11:20 AM
Anyone???
Borgie is offline
Old 08-25-2013 | 01:06 PM
rws's Avatar
rws
I dont think the Vortec heads came on an L-19 but on the lighter duty L-29 pickup engine.I just did a valve job on an L-29 this spring at by the way the exhaust valve faces were beat, up i doubt they are inconel.
I would try to find a set of 781 or 049 casting number heads .
rws is offline
Old 08-25-2013 | 01:28 PM
Inserted 19, instead of 29. Yes these are the L-29 and I plan on running flat tops, so 781 or 049's won't work. I'm modeling my build after "330 on roids" with some minor changes. He made 460hp with L-29 heads. I know for sure the seats are hardened, but have heard some came with inconel exhaust valves for the towing duty these engines were subjected to. My valves look awesome in these used heads. Tried to find an aftermarket inconel 1.72 valve with no luck. GM has them though.
Borgie is offline
Old 08-25-2013 | 09:29 PM
Full Force's Avatar
pull a valve on the manly Inconel magnet will stick until you slide down and hit the Inconel part, that may be a way to tell, or look for part number...
Full Force is offline
Old 08-28-2013 | 05:48 PM
I have read in several places the 454 Vortec truck engine used Inconel valves. And so did the 8.1L truck engine. Inconel is great for withstanding heat, but like any valve, will get damaged from valvetrain issues, weak valve springs, detonation, etc.
MILD THUNDER is offline
Old 08-28-2013 | 06:35 PM
Full Force's Avatar
I will post a pic later of one from my boat. Never seen a valve do this before!!
Old 08-28-2013 | 06:43 PM
Full Force's Avatar
[ATTACH=CONFIG]507127[/ATTACH]
This was one of my inconel after a very lean condition of fuel starvation... If this was a regular valve I woulda been screwed!!!!
Attached Thumbnails 1999 7.4 vortec L-19 heads inconel exhaust valves?-image.jpg
Old 08-30-2013 | 10:42 AM
lucky it was inconel. a reglar valve woulda pro bably dropped the head right off...
dereknkathy is offline
Old 09-10-2013 | 04:31 PM
Thanks for the help guys. Decided the L-29 heads are a waste of time and money. Going for either Dart iron eagle 308's or AFR's on a 496. Might as well do it right and ensure inconel valves are used in a good flowing head!
Borgie is offline
