Bravo III Gimbal Bearing Replacement >
Old 08-27-2013 | 12:30 PM
Default Bravo III Gimbal Bearing Replacement
Just got an estimate for replacing the port gimbal bearing of $4500 to $5500 clams. Ouch. It listed removing the hatch and pulling the port engine. Anyone have an idea of an easier way to do this? I thought it was all accessible from the stern by removing the outdrive.
glboatdriver is offline
Old 08-27-2013 | 12:42 PM
Knot 4 Me's Avatar
No need to pull the motor to replace a gimbal bearing. Just the drive. Did they mistakenly quote you a gimbal ring replacement?
Knot 4 Me is offline
Old 08-27-2013 | 03:57 PM
Yep. They quoted replacing the gimbal ring, bearing, upper shaft, steering lever and nuts.
Ouch!
Old 08-27-2013 | 07:26 PM
Mbam's Avatar
Offshoreonly Advertiser
I hate to say without seeing but that sounds ..... high!
We sell a complete new transom assembly for $2095, yes engine removal is required. Unless you have a really difficult engine to remove the whole job should not be more than 12-16 hours. And you wind up with all new stuff. What else is in the quote?
Mbam is offline
Old 08-27-2013 | 09:47 PM
I'll probably shop for comparables before doing it, but the folks who gave me the quote have been good to us so far. Still, it is a big pill to swallow. I'm adding a tie bar to tighten things up a bit and delay having to spend the bucks!
Old 08-28-2013 | 12:01 AM
BUP
$ 5500 is more like doing both engines and gimbal rings or least close to it..For the parts listed above it shouldn't be any higher than $ 3500 per side (IMO thats on high side of thinks and I do this for a living) unless some fiberglass cutting and reglassing needs to take place getting the engine out and back in.
BUP is offline
Old 08-30-2013 | 09:10 PM
bowtie's Avatar
I agree with Marc, 12 hours should be 1200.00 or so and the cost of the gimbal assy. But without seeing the boat I wouldn't quote a price. Remember marina's have to charge for each person working on the boat so if they use 4 guys removing the engine hatch that's probably 400 bucks right there.
bowtie is offline
Old 08-30-2013 | 09:25 PM
Thanks all!
I'm going to limp it along for another year with a tie bar added on and will probably replace the ring next year. That'll give me time to save up!
