ii you were looking at two identical boats 1 w/ alphas the otr w/ trs which wud u buy >
Old 08-30-2013 | 10:46 PM
ratman's Avatar
Default ii you were looking at two identical boats 1 w/ alphas the otr w/ trs which wud u buy
wondering what is the better drive set up. the trs on one boat is the original set up, the alphas were swapped out for the original trs on the other boat...both have sbc engs.
which would you go with and why? thx, rm
ratman is offline
Old 08-30-2013 | 10:49 PM
The only reason I would go with Alphas is the availability of parts.
POWERPLAY J is offline
Old 08-30-2013 | 10:55 PM
Agreed,,,As tough as it is to find TRS parts here in the US...it will be next to impossible to find TRS parts in South America.
sprink58 is offline
Old 08-30-2013 | 10:57 PM
Small blocks and trs? If there good now change the fluid and I don't see why they would ever break.
Unlimited jd is offline
Old 08-30-2013 | 11:10 PM
ratman's Avatar
wow i didn't know it was tuff to find parts for the trs drives in the states. did merc stop making parts for them?
i have magnum fever goin on, i may get over it in the next day or two... i think the 32 manta im looking at will serve my needs better than a closed deck magnum, now if i come across a magnum cc before tues it on...
i am building a pro touring 67 camaro and a blown 48 anglia right now here in colombia. i bring all my parts down from the states but this stuff is easy to find... thx for the advice, rm
ratman is offline
Old 08-30-2013 | 11:16 PM
ratman's Avatar
what about the MerCruiser velvet drive transmissions, are they bullet proof behind small blocks?
keep in mind when ever i puke one engine they are going to be stroked to 388s, but i see a lot of bbc 330s in front of the trs & trans set up. they seem to hold up as long as you dont build the engines into monsters...
ratman is offline
Old 08-30-2013 | 11:30 PM
Randy Nielsen's Avatar
I rebuilt the merctrans in a boat with a small block & trs they are very simple & use ford c6 clutches and I believe a band from a fmx. The input shaft is tiny though, if your not hot rodding with it, it should last a long time. Randy
Randy Nielsen is offline
Old 08-30-2013 | 11:33 PM
Wow....thought about posting a smart assed remark but really not worth the time.
Good Luck Rat.
RebarBox is offline
Old 08-30-2013 | 11:36 PM
ratman's Avatar
Good Luck Rat.
bring it...lol
humor is always appreciated by someone
ratman is offline
Old 08-31-2013 | 09:19 AM
Does it have velvet drives or merc trans?
