454 getting hot at wot >
Old 09-03-2013 | 03:50 PM
Default 454 getting hot at wot
So my port side motor always runs around 165-170 cruising around and normal usuage, but when I run it hard it goes up to 185-190 range. This motor also steams out of the exhaust always and it diesels on shut off sometimes.
Jg1000 is offline
Old 09-03-2013 | 04:18 PM
And what have you checked?
nonstop is offline
Old 09-03-2013 | 07:37 PM
johnnyboatman's Avatar
check the timing if its dieseling, will cause it to run hotter, do you have water flow not just pressure,
johnnyboatman is offline
Old 09-03-2013 | 07:47 PM
if it is jetted to lean it will cause a lot of heat,that and retarted timing may be the issue.what is the total timing?
mike tkach is offline
Old 09-04-2013 | 10:05 AM
I will check the timing. I don't have water pressure gauges so not sure on that. Sea water pump is brand new and did the same thing with the last seawater pump. I did have the seawater pump fail in less than a year on that motor but it was a sea choice or some knock off instead of a mercury. I wondering if there's a restriction someplace.
Jg1000 is offline
Old 09-05-2013 | 10:03 AM
maybe not a bad idea to install transparent hose between steering cooler and thermostat housing to see if any air bubles in the system
babalu is offline
