Exhaust Elbow Leak
Saw a little water bubbling out from the exhaust elbow gasket, how easy is the change out? Simple do it yourself, or take to the mechanic? 1997 HP500, mercruiser exhaust, with the Gil Risers. Motor rebuilt in spring of 2011, (new gaskets). Looks like replacing 23 & 26 in pic.
Thanks in advance.
[ATTACH=CONFIG]507487[/ATTACH]
Thanks in advance.
Hopefully the moisture you are seeing is just from the condensation collected on the turbulator (part 26) and not from reversion as those are dry joint manifolds/risers. You should only need the two gaskets (part number 23).
