Does the 72C use the same tail housing for #5 drives and TRS drives? >
Old 09-09-2013 | 06:05 PM
Default Does the 72C use the same tail housing for #5 drives and TRS drives?
Thanks,
cyrus77 is offline
Old 09-10-2013 | 06:33 AM
No it doesn't, it uses a plug in tail that moves the engine and trans back 3"
Unlimited jd is offline
Old 09-10-2013 | 07:43 AM
MER Performance's Avatar
The tail stock for the TRS is smaller in diameter where it slides into the transom assy. The shaft diameter on the input of the drive is different.
If you are looking for a #3,4 or 5 tail stock; I have 1 left. If you find some worn out ones, they can be rebuilt with all the bearings, sleeves and seals from Timken.
MER Performance is offline
Old 09-10-2013 | 06:11 PM
I have a couple TRS tail housings if that's what you need. Would take a SSM in on trade for them
MILD THUNDER is offline
