496 425hp or 375hp >
496 425hp or 375hp
496 425hp or 375hp
Old 09-10-2013 | 04:52 PM
Default 496 425hp or 375hp
is there a way to identify a merc 496 if it is a 375 hp or 425 hp other than by the pcm . i know that i don t have the correct pcm on my motor . i do have the serial # 0w695839
tazdevil is offline
Old 09-10-2013 | 05:16 PM
Should be a plate right on the heat exchanger that says if it is a HO or not. HO is 425, non HO is 375. At least that is where mine is.
Questofpower is offline
Old 09-10-2013 | 10:58 PM
your pcm should say h.o. on it.
BIGBREW is offline
Old 09-11-2013 | 02:52 PM
Any Merc dealer can run the serial number and tell you exactly what it is.
Griff is offline
Old 09-11-2013 | 02:55 PM
the sounds of a Ho is lumpy and regular mag is smooth.
mittens is offline
Old 09-13-2013 | 10:23 PM
He is correct, My 496 sounds built, A little lumpy cam should be noticeable, when at idle. Where is your H.O. runs between 4600-5000 rpm for best HP and I think the 496 runs around 4600 rpm, If you look on the pcm looking at the front of the motor the pcm should be over the passenger side of the motor and mine says H.O. right on it.
BIGBREW is offline
Old 09-14-2013 | 09:19 AM
pqjack is offline
Old 09-14-2013 | 09:20 AM
+1
pqjack is offline
Old 09-14-2013 | 10:29 AM
Op wrote
. I know that I don t have the correct pcm on my motor
Also, the Engine # does not match anything @ http://www.mercurymarine.com/parts-a...parts-catalog/
You might want to get a better look at the engine # and do a search in the link above. There I am sure you can find out what engine spec you have.
Michael S is offline
Old 09-14-2013 | 08:40 PM
thanks Micheal S but no luck it gives me both options
tazdevil is offline
