Need Help with Decal Remover >
Old 08-05-2002 | 09:25 PM
Default Need Help with Decal Remover
I'm trying to remove some decals from an older boat. Actually got the decals themselves off but am left with the adhesive stuck on the gelcoat. I tried a light application of acetone....no luck. tried gasoline..a litle better but this adhesive is tough. What can I use that won't damage the gelcoat?
AGGRAVATION28 is offline
Old 08-05-2002 | 09:27 PM
Hauling Trash's Avatar
Try more acetone ,try goof-off it work great too
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
Old 08-05-2002 | 09:37 PM
Ted G's Avatar
De Solv It works well also.
www.cbpba.com
Ted G is offline
Old 08-05-2002 | 09:53 PM
Secret F233
Ya Mike's right about Goof Off. also try Goo Gone still had wax on the Spyder after using it.
Old 08-05-2002 | 09:59 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
3M Adhesive Remover is the &^%$. You will probably have to get it from an auto body supply shop. I used it to take off the black SONIC stickers on my boat.
M1 Remover from Home Depot is also good, but the 3M stuff is better.
Sydwayz is offline
Old 08-05-2002 | 10:36 PM
bajadude's Avatar
Sticker Off
Here's the stuff that I use. Sticker On is good for putting decals on too.
bajadude is offline
Old 08-06-2002 | 11:05 AM
Strike's Avatar
If you don't have a heat gun (set on low), use a hair drier. Just don't hold in one place too long. We do that along with a plastic razor blade to help peal it off. Works great!
Strike is offline
Old 08-06-2002 | 11:39 AM
I have always had good luck with spray carb cleaner
John
John H is offline
Old 08-06-2002 | 11:51 AM
Wild Horses
Use Goo-Gone
Even works on sled windshields to remove the sticky stuff from last years trail permit.
jdub
Detailing, Painting, & Fiberglass
9
10-17-2010 07:25 PM
Pantera24
13
10-17-2005 02:02 PM
SeaWeasel
0
06-01-2004 12:05 PM
rockstrmkr
07-03-2002 11:49 PM
