Boost retard >
Boost retard
Boost retard
Old 09-14-2013 | 12:15 PM
Default Boost retard
How important is boost retard with only a maximum of 4 lbs boost? Im trying to keep my octane in the 90's for this reason and have no noticeable signs of detonation.
ba3367 is offline
Old 09-14-2013 | 03:50 PM
GPM
How important are melted pistons and blown head gaskets, what is the timing set at now, what compression ratio, what head material, what cam, is there an intercooler, need a little more info.
GPM is offline
Old 09-14-2013 | 06:52 PM
I just bought this boat less than a month ago. Don't know a whole lot about the motor. What I can tell you is no inter cooler, cast heads, 34 degrees full advance, roller cam ( lift n duration unknown). Working on getting more info on the engine build but no luck yet.
ba3367 is offline
Old 09-14-2013 | 07:13 PM
GPM
I'm not an engine builder, just thinking 34 might be best suited for an N/A motor, what's the water temp when it's warmed up and running wide open.
GPM is offline
Old 09-14-2013 | 07:21 PM
About 180 degrees and it is a carbureted ( n/a ) motor.
ba3367 is offline
Old 09-14-2013 | 07:24 PM
If its less than 8:1 compression with a specific blower cam, and an appropriately sized blower, I'd drop it to 32 and leave it. No need for boost retard. In fact lowering timing too far is more dangerous.
Unlimited jd is offline
Old 09-14-2013 | 07:32 PM
If it hasn't blown up yet, chances are it won't. I might think about dropping the timing back to 32*, but without knowing more about the engine specs, its hard to say for sure.
Griff is offline
Old 09-14-2013 | 07:44 PM
having built quite a few blower motors,its of my opinion to keep timing at 30 degrees and 93 octane
proboat-wes is offline
Old 09-14-2013 | 07:56 PM
GPM
[QUOTE=ba3367;3995960]About 180 degrees and it is a carbureted ( n/a ) motor.[/QUO
I'm confused N/A or blower with 4psi
GPM is offline
Old 09-14-2013 | 07:57 PM
Well it's my understanding they the motor was built specifically for the weiand 177 application but unless I can get the build specs I'm kinda in the dark unless I do a tear down and I don't know that it's worth all that without an eminent issue. Off that subject how do I attach images from my iPhone photo library?
ba3367 is offline
