Switches
Old 09-16-2013 | 07:44 AM
Default Switches
Does anyone know where to find these switches? Who makes them? They can be LED lighted tip or non-lighted, either one. Thanks.
[ATTACH=CONFIG]508070[/ATTACH][ATTACH=CONFIG]508071[/ATTACH]
frickstyle is offline
Old 09-17-2013 | 07:41 AM
Switches are made by Carling. There 12Volt Lighted Toggle Switch(s). Not sure if you will find green led ones, the ones I have bought for my Baja were red or clear. Grainger has them for $5 or so. Greatlakeskipper has them for $10, also search eBay.
92nsx is offline
Old 09-17-2013 | 07:43 AM
Great, thanks so much!
Old 09-19-2013 | 06:53 AM
These are a little expensive but very good quality. Aircraft/marine grade integral circuit breaker. I have them in my boat, not lighted though.
http://cmsquick.com/prod_24_AP_UPGN.html
Airpax is the brand
pstorti is offline
Old 10-23-2013 | 05:18 PM
Airpax is the brand
Airpax and Carling both make "switch rated" circuit breakers. I use these on my 12v switch panel so that I don't need separate circuit breakers or a fuse box.
starbright55 is offline
Old 10-23-2013 | 10:02 PM
I haven't used the Carling version are they as good as the Airpax? I think they are great also makes wiring easier and better IMO.
pstorti is offline
Old 10-23-2013 | 10:20 PM
J-Bonz's Avatar
I tried looking online everywhere for them but had no luck. I broke down and ordered from Philly.
J-Bonz is offline
Old 10-24-2013 | 11:59 AM
I own a used Navy boat so they spec either the Carling or the Airpax. I think that they are both very good (same dimensions, I have them mixed in my panel). I agree, the wiring is much simpler and it saves space.
Carling info:
http://www.carlingtech.com/hm-cb-ms-series
"Ideally suited for COTS (commercial off the shelf) military applications, the MS-Series features a durable metal and sealed mounting bushing with MIL-PRF-39019F ingress protection when mounted in a panel." Basically, that says "heavy duty & waterproof".
Not too many place stock them and they don't some in every amperage rating (for a sonar that spec'd 3A, I put in a 2.5A). I bought from from these guys: http://www.bassproducts.com/ just because they made the orig 12v panel in my boat.
Old 10-25-2013 | 10:26 AM
everywhere except the link I posted where you can buy them
pstorti is offline
Old 10-26-2013 | 12:38 PM
J-Bonz's Avatar
J-Bonz is offline
