Best way to Modify tank for larger pickup? >
Old 09-20-2013 | 11:55 AM
Default Best way to Modify tank for larger pickup?
I'm replacing the stock 454 mag with a 530hp 6200rpm 440, and need to know what the best way is to enlarge my fuel pickup? It's an aluminum tank with a screw in 3/8 pickup tube, and I figure I need to step up to at least 1/2" if not 5/8" just for good measure. I can't pull the tank without completely cutting it out and removing the floor. Am I wrong in thinking the only way to do this is to cut a hole in the top of the tank, and bolt down a plate over it with a larger bung welded on? What's the best way of doing this without getting tons of shavings into the tank, or the best way of removing those shavings?
Waveform is offline
Old 09-20-2013 | 12:20 PM
If a 3/8" Inside diameter pickup will fit as it is that is enough fuel for 575-600 hp so I wouldn't worry.
Unlimited jd is offline
Old 09-20-2013 | 01:08 PM
Agreed, leave it alone until you know its a problem
kevinb230 is offline
Old 09-20-2013 | 01:31 PM
I thought 475-500 was the limit for 3/8? I'm running -8 to everything, and don't want the pickup to be my choke point. The engine has yet to be installed, and I don't have enough room to change anything once it is.
Here are the Engine Specs
440 Cubic Inch BBC 525 hp @ 6000 rpms
Block-
Decked
Align Honed
Bored .060 over
Steam holes drilled
Bore notched
Rotating assembly:
GM Forged Crank, NOS 3.76 Stroke
Eagle H Beam Rods- Resized at Wesco
SRP Forged Domed Pistons
ATI Super Damper
Valve Train:
AFR 265 Oval Port Heads CNC Chambers, inconel Exhaust Valves
Morel Roller Lifters
Scorpion Endurance Marine Rockers
Marine Kinetics Roller Cam
234/240 .63/.61
Fuel System:
Weiand Stealth Intake
Pro Systems HP Holley, 830 CFM
Holley Marine Fuel Pump
Waveform is offline
Old 09-20-2013 | 01:49 PM
Mbam's Avatar
Offshoreonly Advertiser
Can you post a photo of the existing pickup and tank bung?
Mbam is offline
Old 09-20-2013 | 01:57 PM
Merc 900's only have -10 feeding them. Most hp 500 and 525 boats have 3/8. As Marc said, best bet is to post a picture to be sure.
Old 09-20-2013 | 02:01 PM
The boat is about an hour away, and I don't know when I'll be able to make it out there, but here is a pic of a very similar pickup tube although on mine the tube isn't welded to the fitting, it looks to be threaded in, and the bung is just welded to the top of the tank.
Waveform is offline
Old 09-20-2013 | 02:06 PM
This is the only pic I could find that even shows the tank, and it's before all the work I've done so please excuse the mess
and here is the pic I mentioned in my prior post but forgot to actually post.
Waveform is offline
Old 09-20-2013 | 02:09 PM
A -8 is enough to support up to 800hp on e-85! But it's always good to check everything while your in there!
KRAUSMOTORSPORTS is offline
Old 09-20-2013 | 05:22 PM
We run the stock 1987 Wellcraft pick-ups with almost 800 HP NA. My guess is they are 3/8" as they are original and the boat had the Merc 370HP new. We also run -6 lines from the tank thru the fuel cut-offs and then to the fuel/water separators. We have -8 SS braided from the F/W separators to the carb...why?...bling. We hold 7lbs of fuel pressure at WOT. Just the facts, not opinion. There are lots of ways to improve preformance in your boat, but larger fuel lines won't add anything but cost. As long as you can hold 6.5 of fuel pressure at the carb fuel rail, you are good to go.
BenPerfected is offline
