camshaft for marine vortec 350
Brian
here is your cam. http://www.summitracing.com/parts/nal-14097395 I would go bigger. And also its a 109 cam, most marine cams are 112 lobe separation as to avoid reversion.
With the vortec heads and other L31 engine parts, I believe this is good for 290 - 300 HP depending on intake and carb. It is a pretty conservative cam for a 350 vortec, like others have mentioned you can build more power with a more aggressive cam, but I can attest to the fact that they idle nice and are very well behaved.
Brian
You are correct...any lift over about .480 causes a bind in the lighter stock spring. Larger more robust springs require relieving the spring pocket to accept a more substantial and larger diameter spring.
A comp cam xm 276 would be as hot as one would want to go with wet exhasut a xm270 would be quite nice.You will notice it reqire's some modification's..and ground on a 112 lsa
http://www.carcraft.com/techarticles...pring_upgrade/
http://www.pacificp.com/forum/viewto...d21288c9eebedd
Page 2 is where the meat of the conversion come's to light
The below should be part of the thought process
http://www.perfprotech.com/blog/unca...d-and-checking
http://www.michel-christen.com/ExhaustElbows.pdf
