Pantera 280 what year is it? >
Old 09-24-2013 | 09:58 AM
Default Pantera 280 what year is it?
Hi, need some help here. just bought this Pantera 28 but have no idea what year it is. Do they all look the same or can anyone identify the year (approx.) by the lines etc etc?
It has 2 MAG 350 with Alpha drives on it but these will go out. Now I plan on putting two new 377 Scorpion Mercruisers in with Bravo 1 drives as I do not want any high performance engine that is heavy on maintenance. That being said, I would consider a 525 if this would improve the jumps???? The two 377 Mercruisers might be to heavy in the back to make it land nice and flat compared to the 525? I do like the idea of 700+ HP split on two fairly simple engines though. Am I too optimistic if I hope to pass 70 miles with the two engine set up?
[IMG]1.jpg[/IMG]
Knallan77 is offline
Old 09-24-2013 | 10:00 AM
ok that is sad....... I don't know how to attach pictures it seems........ is there a trick to it?
Old 09-24-2013 | 11:21 AM
Where are you getting the 377's?
mptrimshop is offline
Old 09-24-2013 | 12:37 PM
The last 2 digits of the HIN should be the year.
Griff is offline
Old 09-25-2013 | 02:33 AM
Ok thanks will try to find the HIN.
for the engines, note that im from Denmark so i will get them either here if i get a good deal on two or from Germany where the VAT is lower;-)
Old 10-14-2013 | 11:03 AM
Old 10-14-2013 | 11:05 AM
[IMG][/IMG]
Old 10-14-2013 | 11:38 AM
ratman's Avatar
that boat should run 70 no problem with twin small blocks...
you can build 383 small block chevys very inexpensively, just use your 350 engines, buy a pair of skat cast cranks and pistons from summit racing, arp studs for the main caps, arp rod bolts, some ss valves, inconel valves for the exhaust, have the rotating assemblies balanced, and a pair of roller cams....
ratman is offline
Old 10-14-2013 | 07:26 PM
Craney's Avatar
I don't think you will hit 70 with those small blocks more like 60 to 65.
Craney is offline
