Supercharging 454's >
Supercharging 454's
Supercharging 454's
Old 08-06-2002 | 06:32 PM
X-Rated30's Avatar
Default Supercharging 454's
Last year I replaced gen IV 454/425's with new gen VI 454/425's. They don't seem to have quite the bump I wanted, but are definitely adequate. (Have gotten mid 70's gps.)
The new motors are the 454HO crate motors from GM performance. They have hydraulic roller lifters, and compression is 8.75:1. Heads are cast iron rectangular port 118cc.
I am toying with the idea of supercharging them. I don't want to destroy the motors, and I thought a slower turning larger blower might be the way to do it.
I have two questions:
1) should I supercharge these motors at all? If so, what if anything would I need to change inside the motor.
2) what kind of blower/setup would you suggest?
X-Rated30 is offline
Old 08-06-2002 | 06:54 PM
Are these marine motors? I procharged my Merc. 454 with great results. Reliability is all in the initial set up and how the driver runs the motor.
Pure Energy is offline
Old 08-06-2002 | 10:43 PM
X-Rated30's Avatar
They are souped up car motors. It is a fresh water boat, so the main worry was getting torque in the right places. The sheets on them say 500 lbs of torque at 3250 rpms. Can't dissagree with that. The low end is fine -- the top end dies out a little soon for my tastes, though.
Old 08-06-2002 | 11:09 PM
There is more to it than where peak torque and hp are. I am no mechanic but I do know that some of the tolerances and clearances are diff. Marine motors are built to withstand the severe load they have to endure. Auto engines are not built the same. I am sure there are others here that can shed more light on the subject.
Old 08-07-2002 | 08:01 AM
KAAMA's Avatar
Sgrady (OSO board member) has had experience with Pro Chargers in a boat he once owned before. Wolff installed them and got them running well for him. Maybe he will chime in here.
KAAMA is offline
Old 08-08-2002 | 03:55 PM
X-Rated30's Avatar
I'm moving this post to the main board to get a little more input. If you want to respond, please post it there.
THX!
Old 08-08-2002 | 06:12 PM
Turbojack's Avatar
Change the cam shaft. Not a real good one for marine use, so I have been told. Then procharge them! Got buddy on third season with 2 of them & no problems.
Turbojack is offline
Old 08-09-2002 | 07:01 PM
Car Craft Aug 2002 just did this, it's a great article.
Found stock GM crate 454HO put out 472HP with stock auto manifolds, and 481HP with headers.
472 HP--stock
481 HP-- +headers
490 HP-- +mighty demon carb
506 HP-- + Edelbrock performer rpm dual plane manifold
508 HP and -30 TQ-- + Edelbrock victor jr. single plane manifold
532HP-- + Crane cam #168761 230/236 degree, .598/.610
plus lifters and springs = $1000.
779HP-- + Vortech SC at 7 pounds boost @ 6100, and 706 TQ @5500 (victor jr manifold), no intercooler, 91 octane gas.
It is a little high in the rpm range and I would love to see this with the stock cam (save $1000) and the Air gap manifold.
cobra marty is offline
perform330
06-15-2007 09:28 AM
cstobe
11
11-21-2006 02:25 PM
X-Rated30
08-13-2002 10:35 PM
fishead
3
05-20-2002 05:14 PM
dean campbell
Sunsation
11
04-29-2002 04:46 PM
