Go Back  Offshoreonly.com > Owners Forum > Eliminator
Drive for 2001 Daytona 26 >
Old 09-30-2013 | 08:08 PM
Tinkerer's Avatar
Default Drive for 2001 Daytona 26
I am looking into putting a Blackhawk drive on my boat. What are your thoughts and at what height should the propshaft be. The measurements show that if I install the drive on the boat as the gimbals are now the bottom of the bullet will be about even with the bottom of the boat 1 foot forward holding a straight edge on the bottom of the sponsons.
I have a -2 IMCO shortie on it now and the prop shaft is one inch below the above mentioned line.
I have been told that it should be 1 inch above with a Bravo drive.
Steve
Tinkerer is offline
Old 09-30-2013 | 08:38 PM
Turbojack's Avatar
The 26 I had a 2" shorty and it was 1" above. I had gained 8 mph from the stock lower.
What motor do you have?
Give it a try and let us know the outcome.
Turbojack is offline
Old 10-01-2013 | 05:50 AM
bor's Avatar
bor
I die à lot of research on the blackhawk als I Used one on my 21 vhull and the bullet has to be above the Bottom of your boat to work best .
But your hull have to like it mine didn t .
There s à lot info on donzi.net about the blackhawk.
bor is offline
Old 10-04-2013 | 11:44 AM
Gary Misenberg worked for mercury marine in developing the blackhawk drive. He should be able to help you with the dimensions if you still need help. 503 545 2469
CaliEliminator is offline
