Bravo prop shaft,lower gear set,,vertical shaft >
Old 10-04-2013 | 09:51 AM
Default Bravo prop shaft,lower gear set,,vertical shaft
used lower gear set,,vertical and prop shaft,,$300.00 +shipping
Attached Thumbnails Bravo prop shaft,lower gear set,,vertical shaft-prop-shaft.jpg
boatnt is offline
Old 10-18-2013 | 09:19 AM
$250.00 +shipping
boatnt is offline
Old 04-06-2014 | 09:33 AM
ttt
boatnt is offline
Old 08-28-2014 | 07:22 PM
Do you still have this for sale? Will you sell prop shaft seperately? If so, price?
jbdykes is offline
Old 08-28-2014 | 07:43 PM
have the prop shaft ,,$125.00 +shipping
boatnt is offline
Old 08-28-2014 | 09:31 PM
I would like to have the gears if they are good. Are they the same as an XR? 1.5 ratio?
snapmorgan is offline
Old 08-29-2014 | 05:36 AM
Please confirm this is a one inch shaft (fits bravo x drive)
jbdykes is offline
Old 08-29-2014 | 06:18 AM
do not know guys ,,they came off a standard bravo,1 inch shaft 1.5 ratio
boatnt is offline
Old 08-29-2014 | 11:11 AM
If its a one inch, it won't fit an xr. Checking if I can use on my x drive. Do you have the serial number for the prop shaft?
jbdykes is offline
Old 08-29-2014 | 05:38 PM
Can you contact me at [email protected]. Pretty sure this is the part I need.
jbdykes is offline
