hydromotive QIV-X 28p lh and rh props with torque flow hub s >
Old 10-04-2013 | 10:01 PM
Default hydromotive QIV-X 28p lh and rh props with torque flow hub s
set of hydromotive QIV-X 28p props. Comes with torque flow hub and brass adapter for small merc shafts. On th rh prop there is one blade that is a hair out. I had it fixed at a marina when I was out on the water to get home. I can see it is out but it didn't make any difference in performance. They are not polished I cleaned them up with some 800 grit sand paper since last time I was out they were in salt water and got a little surface discoloration after sitting for a couple of months. Make me a reasonable offer. Send me a email address for pics. Thanks
demag67 is offline
Old 10-11-2013 | 12:10 PM
[email protected]
payuppsucker is offline
Old 10-14-2013 | 01:34 AM
500 plus the ride. Comes with hubs just need thrust washers and nuts and your good to go
demag67 is offline
