Areomotive a1000 pump getting weak? loosing prime >
Old 10-05-2013 | 11:53 PM
Strip Poker 388's Avatar
Rob
Question Areomotive a1000 pump getting weak? loosing prime
Ive got one pump thats getting weak, clearances opening up, looseing prim, I hav eto turn the key on 5-9 times to get the presure up so i dont stress the starater, These are 2001 the old design that had the problems with glue coming loose in the windings and putting trash all the the system, they have been rebuilt,updated years back,something is going on now, I tried contacting areomotive and they want respond, the new price is around 330. now
anybody else have this problem? maybe the ethonal is working on the, I know Im having fuel line failures.
Thnaks for any sugestions
Rob
it does not have fuelwater seperators any more
Attached Thumbnails Areomotive a1000 pump getting weak? loosing prime-hustler-insatll-3-15-06-004.jpg
Strip Poker 388 is offline
Old 10-06-2013 | 06:12 AM
Nice rigging! You know the answer....
BenPerfected is offline
Old 10-06-2013 | 08:16 AM
look at the screens on the input side of the pump.bet its clogged up.or you could send them to me for parts.
sutphen 30 is offline
Old 10-06-2013 | 09:54 AM
make sure you are getting good voltage thru a relay...but sounds like it's on the deathbed..
ezstriper is offline
Old 10-06-2013 | 11:01 AM
Rob
If the voltage was down I would think it would show up as not pumping enough when running,
I looked in the pump inlet and didn't see a screen
I have a spare ive been using as a transfer pump,prob swap out see if theirs a difference/
ALSO I added a inline filter just incase the pumps puke again and to protect the injectors. maybe this is causing a problem
The best I can remember around 2003-05 they charger around 175.00 to rebuild their first poor designed pump,i guess I ll call them next week see whats up again.
[ATTACH=CONFIG]509308[/ATTACH][ATTACH=CONFIG]509307[/ATTACH][ATTACH=CONFIG]509309[/ATTACH][ATTACH=CONFIG]509310[/ATTACH]
Attached Thumbnails Areomotive a1000 pump getting weak? loosing prime-hustler-interior-pick-up-024.jpg   Areomotive a1000 pump getting weak? loosing prime-hustler-5-013.jpg   Areomotive a1000 pump getting weak? loosing prime-whipple-3.3-005.jpg
Old 10-07-2013 | 08:36 AM
I have had the same pump get weak on me but this was only in a Toyota Supra years back.
Aero said it was due to ethanol in the fuel I was running. I sent it back to them for the "update" that is ethanol friendly, and rebuild. IIRC it was $170 or so. I ended up parting out the car and buying My Baja. But I know the older model A1000 pumps did not like ethanol. That was my experience with that pump. Hope this helps.
Side not: DAM was that on loud ass pump!!!!!
92nsx is offline
Old 10-07-2013 | 01:05 PM
Rob
I prob need to send them back and get checked out,updated, they were rebuild before ethenoal
Old 10-07-2013 | 08:40 PM
Scarab28's Avatar
Just had same pump become unable to hold pressure under boost. Replaced pump and issue went away. Pump was only about 3-4 yrs old.
Scarab28 is offline
Old 10-08-2013 | 09:28 AM
Consider upgrading to the Weldon marine pumps. The bad part would be rerigging for them, and paying for them. Why have an essential part that is questionable for your hp?
SkiDoc is offline
Old 10-08-2013 | 11:40 AM
Second that, get a set of Weldons !!!
cmd1962 is offline
