fuel pressure gauge help... >
Old 10-09-2013 | 08:26 PM
whiskeyhangover's Avatar
Default fuel pressure gauge help...
I'm looking into adding 2 electric fuel pressure gauges to the dash for my 502 EFI's and I have 2 questions:
What is a good cost effective fuel pressure gauge and sender?
Where is a good place to add the sender? if you can't attach it to the front shrader valve.....
Thanks.
whiskeyhangover is offline
Old 10-09-2013 | 09:10 PM
You really can't go wrong with Livorsi gauges. They are standard equipment in a large number of new boats. You can remove the schraeder valve and put the sender in it's place. That port in the rail is 1/4" NPT and the sender will be 1/8" NPT, so you will need to use a bushing. You will probably also need a 90* street ell to turn the sender sideways. The other option is to remotely mount the sender and run a hose to it from the fuel rail.
Eddie
Young Performance is offline
Old 10-09-2013 | 09:51 PM
What kind of bushing? Does the livorsi come with the sending unit?
Old 10-10-2013 | 06:31 AM
I use the Livorsi gauges as well, you have to purchase the sender and gauge to match the fuel pressure you are running EFI vs carb
ezstriper is offline
Old 10-10-2013 | 07:18 AM
Bushing =
92nsx is offline
Old 10-10-2013 | 09:47 AM
Ok thanks.... I'll look them up online or does anybody have the part number for the sender and gauge for EFI system
Old 10-11-2013 | 06:14 AM
just go to their website, the EFI runs much higher pressure and shows matching sender...or give them a call...
Old 10-11-2013 | 08:00 AM
Originally Posted by 92nsx
Bushing =
Lol, that's a coupler/collar.
This is a bushing-
Cole2534 is offline
Old 10-11-2013 | 11:05 AM
Well then he needs a coupler. He has to adapt male 1/4" NPT (fuel rail) to male 1/8" NPT (pressure sensor). So the coupler has to have both female ends
6 in one, 1/2 dozen in the other. Witch one has more? LOL
92nsx is offline
